D60 Crossover
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChadH82, Jul 11, 2001.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Well I've started the crossover setup. This will probably be question 1 of many. My question has to do with the pitman arm. On the off-road.com site they have the write up for a D60 crossover. They use a superlift pitman arm for a 4in. lift on a Phord. I'm going to have close to 8 inches of lift so I was wondering if I should go with a bigger drop or if it would matter. Thanks
    Chad
  2. ChadH82
    May 9, 2001
    400
    Hmm... Question 2. If I'm running close to 8 inches of lift will I need a bent tie rod?
    Chad
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Yes, use that same arm. With that amount of lift (8"), you probably wouldn't need a bent draglink. If it doesn't clear, then grind your crossmember a little. Not much would have to be done if anythough.
    Boss
    89' 1 TON of FUN K5
  4. ChadH82
    May 9, 2001
    400
    Thanks for the info!!
