D60 DRW and hummer wheels
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Apr 10, 2002.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i hear that if you are running a D60 from a dually you can run hummer wheels and you wont have any streeing issues, is this true? and what about width i'd think that this would make the front really wide. if this is good for the front how about the rear will a 14bff with hummer wheels have the same track width as the front. this sounds really good to me cause $50 for a beadlock sound good to me.
  2. fulltopblazer
    fulltopblazer 1/2 ton status
    Aug 1, 2001
    484
    Altus,Oklahoma 73521
    Try to send FSJEEP a pm. I sold him a dually D60 and he put Hummer wheels on it under his blazer.
  3. beater74
    May 29, 2001
    1,749
    atlanta
    thanks /forums/images/icons/smile.gif
  4. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Please post if you get the info. If I put big tires on I might do this, too.
  5. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    There were some hummer wheels on ebay I saw last night, but I think the auction might have ended. They were only at about 250.00 for a set though.
  6. K5BLT4FUN
    K5BLT4FUN 1/2 ton status Premium Member
    Feb 28, 2000
    496
    Peculiar, MO USA
    I am currently exploring this option as well and have found out that the Hummer wheels has a 7.25" back spacing. The D60 Dually front hub has an approx. WMS to WMS of 76.5". The front will not be an issue, however the rear axle is where the problem lies. The GM 14FF from a 3/4T or 1T truck has a WMS to WMS of approx. 67.5" and the GM 14FF from a 3/4T or 1T van has a WMS to WMS of approx. 70.5". Therefore the rear axle will need a either a 4.5" spacer on each side or a 3" spacer on each side depending on what rear axle you use. The widest commercial spacer I have found is 4", and cost $165.00 each. The 3" spacers cost $150.00 each. I hope this information helps. I am now looking at the cost of having the center moved for a more desirable back spacing.
  7. what about using a rear dually axle from a pickup- not the cab-chassie? aren't they like 73 inches? i think there is a guy one Pirate that sells the hummer wheels at a good price. both civilian and military versions
  8. beater74
    May 29, 2001
    1,749
    atlanta
    if yer talking about a dually rear, from what i understand they are all shorter than any SRW 14bolt.
    i talked to daniel over at usa6x6.com he said that i could put 2" spacers on the rear to even thing out. he is also the one to get the hummer wheels from for $50 each.
    fsjeeper has done this mod but i'm not sure what kinda vehicle he did it to, here's his resopnce to a pm i sent him." The hummer rims great on a dually front Dana 60. I bought some dually extensions for my rear single wheel 1 on rear end.
    I did a lot of research on Hummer rims. Some are better than others. What I ended getting was the latter model 2 piece civilian wheels with the one pice rubber beadlock, runflat. These in everyone's opinion are the best. "
    i have thought about this for some time now and i'm still not sold on the hummer wheel thing, i worried about reliability and road manner's, cause down here the trails arn't very close and this trip times range from 1 to 3 hours. and i don't have a tow rig yet. it looks like i'm just gonna machine down my daully hubs.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yeah, the shorter version 14FF is on the cab-and-chassis models, but the D70, which is wider - like 75" or so, is under the fleet side beds with the fiberglass fenders.
  10. K5BLT4FUN
    Feb 28, 2000
    496
    Peculiar, MO USA
    thatK30guy is correct , the D70 dually axle has a WMS to WMS of approx. 74.5". The problem with using the Dually D70 is that the hub would stick out way past the tire/wheel combo and become a catch hazard.
  11. beater74
    May 29, 2001
    1,749
    atlanta
    ohhh i see /forums/images/icons/smile.gif
  12. FSJeeper
    FSJeeper 1/2 ton status
    May 6, 2001
    265
    Texas
    I am running Dana 60 dually hubs in the front, and dually adapters (4") in the rear 1 ton single wheel 14 bolt. Hummer wheels work great with this combination.
    I would also like to throw something else in, I did a lot of research on the various types of hummer wheels there are.
    My conclusion was that the late model 2 piece radial civilian wheels with the one piece rubber runflat/beadlock are the best out of all the other types there are. Just my 2 cents.
  13. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    how offset are the front wheels then after you have a dually D60 and a 4" dually rear spacer? does the front stick out alot farther than the rear?
  14. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Do you have any pics?
  15. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    FSJ, how about moving the center of the rim to a normal backspacing for the rear instead of the spacer? 4WOR had something on a place doing this. If you have beadlocks and on-board air you could just carry a spare tire. Right? Or would that be a bad idea? Even with a spacer in the rear this seems like a good low buck way to go 1 ton. Do the Humvee rims fit over the dually front breaks or is grinding required?
  16. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    whats a dually spacer?
  17. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    any more input?
  18. FSJeeper
    May 6, 2001
    265
    Texas
    Moving the center of the rim would probably be the best solution for running Hummer wheels. I personally like the way they look with the 7.25" backspacing. Plus it was a lot cheaper to buy the dually hubs for the front, and dually adapters in the rear. I bought the dually adapters for $100 used and the dually front hubs for $175 I think.
    With the daully hubs and adapters on the Dana 60/14 bolt, it equals out to 3.25" backspacing over SWH setups.
    You could just carry a spare tire and mount it on the wheel without even taking the wheel off the truck, but it is so hard and time consuming to mount large tires on these wheels, I have a fully setup spare wheel and tire.
    For information, I ended up buying 5 new civilian takeoff rims and runflat/beadlocks from a Hummer dealership for $500 delivered. I could have got the bias tire military rims with the magnesium runflat/beadlock setup for $50 each, I just heard to many things about them versus the late model civy wheels and one piece rubber beadlock/runflat.
  19. FSJeeper
    May 6, 2001
    265
    Texas
    A friend of mine is now selling inserts and also modifying hummer wheels to work on normal applications. He can also do these in any bolt pattern and set backspacing to your specs. Price looks good.
    http://4wdfactory.com/
  20. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Cool, thanks for the link.
