D60 DRW Machining
Discussion in 'The Garage' started by 79k20350, Jul 29, 2005.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    What need to be done to machine drw d60 hubs to srw? ROughly how much does it cost? Thanks guys!
  2. 79k20350
    Nov 22, 2004
    7,757
    Ct
    anyone?
  3. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    What are you looking to do to the 60? Dont know the initials
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    DRW = Dual Rear Wheel
    SRW = Single Rear Wheel
    He is wanting to convert the hubs of a dually to a single wheeled hub.
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    exactly, i know it can be done, im just not sure exactly what need to be done.
  6. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    You need to machine off the wheel stud lugs that are closest to the lockout. Then you should make a plate that goes back on the other lugs. I believe these are usually welded on as well as wheel stud splines engaging in them.
    In the end the lug nuts will hold it all together. The plate is mainly there to reinforce the lugs. Normally the plate is a part of the SRW hub.
  7. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Contact Casey at Wagoner Machine Shop.
    WMS
