D60 drw to srw??
Discussion in 'The Garage' started by blazd88, Dec 14, 2004.
  1. blazd88
    blazd88 1/2 ton status
    Mar 16, 2004
    1,055
    Lubbock, Tx
    has anyone ever just milled off the dually studs and extentions then run longer studs back through where extentions mount and use those for whe wheel studs? does that make sense? what has everyone else done OTHER that spend $375 for the new hubs?
    thanx
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sell the dually hubs to people who want to run hummer beadlocks without recentering them. Then use the cash to help purchase SRW hubs.
    Harley
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Yes, check over on Pirate. Someone there did exactly what you describe.
  4. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    u can do what u are talking about the problem is the drw hub does not have a solid ring around it where it bolts to the caliper, & there is some debate over the strength
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yes you can. i had mine machined and added a wheel mounting surface ring. i had wagoner machine do it, but it will cost ya altest $350 for the pair.
    but do a seach for "cheap hubs" or "gm parts direct" on this board. there was a fella how found a part # and used it on gmpartsdirct.com and got SRW D60 hubs with rotors for $115 each:eek:
  6. beater74
    May 29, 2001
    1,749
    atlanta
  7. cfblade
    cfblade Newbie
    Nov 29, 2004
    the gm part# is15635530 for hub&rotor, races, studs got 2 today for $160 ea. + tax from my gm guy, but gmpartdicrect has them for 120 ea.+ship but never dealt with them
  8. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    I received my SRW D60 hubs the other day from GM Parts Direct. $275.00 for the pair with shipping. Sweet pieces. New hubs, rotors, wheel studs and Timken bearing races in one easy serving (rotors even have the balance weights in the cooling vanes like the o.e. ones did). The hubs look like Dodge units with the Budd name cast into the outer diameter of the "snout" area. The only thing I didn't like about them was the finish on the rotors. They had a very coarse directional finish (lathe cut as opposed to surface ground). it looked like a real fast cut was done on them. I saw that and sent them over to our machine department for a better cut and they came back just bootieful :thumb:.
    I priced out individual pieces and at my cost rotors were, for North American iron, $90.00 each, hubs were $175.00 each and studs were $2.00 each. All totalled, I was looking at $562.00 + tax to buy the bits and pieces and assemble them myself. No thanks...... Point, click, done--ahhhh, much better.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Just an FYI, but the GMPD price may not be what it seems.
    GMPD thread.
  10. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    i have the means to do it for free just needed to know if i was an idiot for thinking that was possible. what is it people are doing to get a solid ring afterwards?
  11. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
  12. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    You could trade them to somebody who wants to switch their crew cab to a dually!!! Like say me for instance. However I won't be ready to do this for some time so probably not much help...
  13. mosesburb
    Apr 20, 2003
    2,175
    132
    Phoenix AZ
    Whenever you are ready, let me know :thumb:.
  14. blazd88
    Mar 16, 2004
    1,055
    Lubbock, Tx
    ya anyone else out there wanna trade? c'mon some one wants to run hummer rims ill help you pay for em!!!
