D60 extended brake line NAPA#?
Discussion in 'The Garage' started by Ned Kelly, Mar 2, 2005.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I searched but couldn't find, but I"m sure it's been covered. Does anyone know a Napa # for an extended rubber brake line for about 4" of lift for a frt D60 (1985)? I don't want to get the expensive Superlifts if I don't have to.
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Try this one-
    It has a wierd lookin metal bracket thing on it that needs to be cut off before it's as long as it is in the pictures. Bolted up fine on my 60 as you can see. It's been awhile since I did this, but I seem to remember having to be alittle creative at the frame mounting end. Be sure you look at that brake line at the store and decide if you want to deal with cutting the bracket thing off of it.
    And this is the Banjo bolt I used-
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    #38872 is the part number I used for my truck with a 4" lift.
    Harley
  4. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Jethro- That sure is a long line! Probably more than I need. I did write down that part # though, in case I ever get my suspension flexy enough to make use of those!
    Harley - did the #38872 fit on a D60? I did see this number mentioned in my search but I wasn't sure it was referred to as fitting a D60 application. If that part # will fit the D60 than that is exactly what I'm looking for.
    Thanks to both of you guys! Ned.:)
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    In one of the threads I found when I used 38872 in the search said that yes they will fit a D60. They said the only problem was that 77-78.5 model D60's used the 7/16" banjo bolt. I believe that the lines can be made to work with those bolts though.
    But if your D60 is from 79 or newer you should be fine from what I found.
    Harley
