D60 front brakes?
Discussion in 'The Garage' started by JUNIOR-K5, Jun 13, 2006.
  1. JUNIOR-K5
    JUNIOR-K5 1/2 ton status
    Dec 20, 2005
    387
    SO.CAL
    I just got some calipers and brakes for my d60.Now can someone school me on how to put on the caliper.What hardware is needed per side.Sorry about the newb. question? its a chevy 60 by the way.Thanks
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    1 tension spring kind of like this [ on its side from this view.
    then 1 some what u shaped slide block.
    then 1 retaning bolt big head allen drive.
    spring on top of wedge thing and wiggle all parts in as holding caliper up in top grove. slide over till you can bolt in the keeper bolt.
  3. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    on the back of the caliper will be a bolt that takes an allen head socket, remove the bolt and use a hammer and a punch to knock out the clip that was being held by the bolt. once the clip is removed the caliper has enough movement to be lifted up and out off the rotor.
