D60 Front Pinion Angle... fix?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Alex_B, Jan 31, 2007.
  1. Alex_B
    Alex_B Registered Member
    Feb 28, 2006
    33
    Newfoundland, Canada
    Well I’m runnin 10 inches of lift on my 81 K30 and my front pinion angle is f**ked. I’m just trying to figure out the easiest way to point my pinion at my t case. Keep in mind the spring perch is machined on the diff.
    P.S. my knuckles will be adjusted to fix the caster.
  2. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Well the right way is not the easiest. I use shims right now, IMHO this is not the right way.
    You need to figure out where the perch needs to be anglewise and then take it to a machine shop, fill the holes, machine the angle into it then redrill and tap the holes, of course the other side is easier just cut off the perch and reweld at the correct angle
  3. chevyguybc
    chevyguybc 1/2 ton status
    Nov 12, 2003
    524
    Vancouver Canada
    that is the proper way to do it, costs 450 canadian ish to get done
  4. MuddinManny
    MuddinManny Banned
    Oct 18, 2006
    1,106
    USA
    This post interests me in a very big way. I have a Superlift 10" Suspension Lift waiting in the wings for installation. I am rebuilding my D60 and the springs have shims attached. So what kind of difficulty am I going to run into. As far as I know the shims did/do the trick. No?
    Manny
  5. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    they do the truck but are not the best way
    i have 4 degree shims in my 7 inch beast, all susp
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Dynatrac offers a solution, but it isn't cheap. Ship them a bare low pinion housing and they'll replace the center section with a custom high pinion housing and ship it back. Last I knew it cost $900 plus the shipping. :yikes:
  7. Alex_B
    Feb 28, 2006
    33
    I had those superlift 10" springs a while back and they SUCK A$$. You'll be lucky to get an inch of suspension travel. Just about any leaf springs that is bigger than 6" of lift has too much arc and are way too stiff.
    What I did to achieve 10" of lift was dropped my front spring hanger down 4", extended my shackles 4", and used a set of BDS 6" springs, now the difference is night and day.
  8. chevyguybc
    Nov 12, 2003
    524
    Vancouver Canada
    what i did for my lift was install a front crossmember, longer shackels, and lifted rear 52" springs
    good for 8 inchs
    the rear is reverse shackel, longer shackel, and 64s with add a lift..
