D60 front u bolts
Discussion in 'OffRoad Design' started by Okiemuddog, Feb 6, 2004.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Stephen I have recently acquired my D60 and I need to know the specs on the the u-bolts. The next questions is, D60's run 3 u-bolts and a set of studs correct? Do they have to be studs? I am unsure if my D60 has the studs or not, it is on its way to me, could I use grade 8 bolts instead or do they have to be studs?
    Thanks,
    Krennen /forums/images/graemlins/thumb.gif
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    If it helps you any, I just bought my ubolts yesterday. 3 ubolts. 2 for the drivers side 3 1/4id x 9" and 1 inner ubolt for the pass side 4"id x 10"
    The other 2 hole I just measuered my springs, spring plate and depth of the hole. I bought 4" long x 5/8th's coarse thread bolts. Couldn't find any studs. Should be fine though..I hope. Let you know in a couple weeks /forums/images/graemlins/tongue.gif
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Our kits come with studs but they're pretty long and sometimes you can't use them and have to go to bolts anyway. A GR8 5/8" coarse thread bolt works just fine if you have to go that route. So, you use 3 ubolts and 2 studs or bolts.
  4. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Thanks Stephen, I knew you would know, almighty master of the D60 /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't know about the "master" part, though the D60 in my K5 knows who the boss is. If it gives me any lip I just get together with Mssr's 42 and 468 and that 60 either behaves or I snap it's little splines right off.
  6. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    yeah spank it!!! /forums/images/graemlins/hack.gif /forums/images/graemlins/yikes.gif
