d60 front
Discussion in '1936-Present Suburban' started by FLASHLIGHT76, Oct 7, 2002.
  1. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    Ok here's the deal, found a line on a d60 front out of a k30. Supposedly complete. Asking $225 what should I worry about for bolting into my sub? I know the calipers won't work off of my d44. Am I going to be replacing brake lines? How about U bolts and spring plates? Will my exsiting sway bar work? Just a few questions. Aaron /forums/images/graemlins/ears.gif
  2. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    When I put my D60 in the K5, all I had to change was the brake lines - went with ORD stainless ones that bolted directly in. Other than that, you need to have the spring plates and new Ubolts since the originals are the wrong size. U-joint in my case matched up. Existing sway bar will work.
  3. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    You'll need new spring plates and u-bolts, as the axle tubes are larger, and there is one ubolt and two studs, and probably brakelines. Try to get the spring plates with the axle if you can, if not chevy dealers have them. Rebuilt calipers are like $12 each with core. Same sway bar. /forums/images/graemlins/deal.gif$225 is a great deal. Don't know much.
  4. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    spring plates u-bolts and brake lines. $225 is AWESOME
  5. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    If for some reason you pass this up, please let me know.
  6. FLASHLIGHT76
    Jun 20, 2002
    255
    OREGON
    Ok here's the deal, False alarm!!!!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gifNeedless to say I was very upset when my friend explained his inability to defereciate between a front and rear axle. /forums/images/graemlins/rolleyes.gifYeah he's clueless /forums/images/graemlins/tongue.gifOh well hopefully he still want's my other axles. /forums/images/graemlins/pimp1.gif
  7. muddysub
    Jun 23, 2001
    10,451
    489
    AW MAN!!!!!!!!! /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/angryfire.gif
