d60 gearing ?'s
Discussion in 'The Garage' started by joefl, Jul 1, 2005.
  1. joefl
    joefl 1/2 ton status
    Aug 18, 2004
    153
    Marianna, Florida
    Im fixing to put in some gears in the front D60. I got 5:13 in the rear. I was thinking on running 5:38 in the front. Would that be to much of difference in gears if I want to drive it on the road every once in awhile? It should be ok as long I keep it in 2x4, correct? It is mainly for mud.
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Why not just put 5.13's in the front also and be done with it?? What's your reasoning for wanting different gears in the front?
  3. muddog
    muddog 1/2 ton status
    Jan 23, 2003
    262
    Cadmus, KS
    i am with 6.2diesel on this one...unless you are waiting for the 14 bolt 5.38's to come out.
    But yes running in 2wd you are not hurting anything....running in 4wd in the mud you take a chance of hurting something..probably a t-case if it is the 208. as long as there is enough slip..(I ran 4.56 front and 5.13 rear for a short while waiting on my gears to get in, but I have an abundance of parts so was not worried about it, also used only when needed)
