D60........help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CAROLINAK5, Nov 25, 2001.
  1. CAROLINAK5
    CAROLINAK5 1/2 ton status
    Aug 2, 2001
    242
    lexington, north carolina
    ok on what vehicles should i look to find a D60?
    i've got a 14 ff that is gonna need a partner.
    also...is it a bolt in replacement for a 10 bolt or are there a lot of adjustments to be made?
    when all else fails..............HIDE!!!!!!!!!!!!!!!!!<img src="http://coloradok5.com/forums/images/icons/shocked.gif">
    &lt;a target="_blank" href=http://coloradok5.com/gallery/albun32&gt;http://coloradok5.com/gallery/albun32&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by CAROLINAK5 on 11/25/01 01:41 PM.</FONT></P>
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    77 and up K30 or V30 (I think that is what they called it the last few years).
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  3. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    Yes it is a bolt in replacement. You can also use one from a dually truck and machine down the hubs to fit single wheel.
    Good luck.
    Mike
    The jeep eater ......jeep it's what's for dinner[​IMG]
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, any from '77 up to '91.
    Like Bad Dog said, '77 up to '86 are called "K30's" and '87 to '91 are called "V30's".
    All D60's are the same except for those with dually hubs. All parts interchange, too.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
