D60 help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLZN4FN, Nov 29, 2001.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok i think I found my D60.
    out of state I have to go and see it.
    The guy in the junk yard thinks it is a 60
    How do I tell if it is a D60? any special tricks
    to tell?
    The axle came out of a 1973 1ton chevy so I hope
    this is a D60 if it is I will get a smoking deal
    he only wants a 100 bucks.
    any help would be helpfull thanks.
    Bo
  2. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    someone please help
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    73 1 ton is a D44 unless it has been changed. To ID a 60, look for a 60 cast into the housing and the passenger side spring perch is cast into the differential housing rather than having a spring perch on the tube (IIRC).
    For more axle ID info, look here
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  4. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the 60 doesnt use balljoints
    there is 4 bolts holding the steering arm in place
    <a target="_blank" href=http://community.webshots.com/album/26127166SwclRTBvgY>http://community.webshots.com/album/26127166SwclRTBvgY</a>
    perhaps you can print these images and take them with you to ID the axle
  5. michaelm
    Feb 2, 2001
    872
    <a target="_blank" href=http://www.gohumvee.com/images/Tech/Dana%2060%20HTML/index.html>http://www.gohumvee.com/images/Tech/Dana%2060%20HTML/index.html</a>
    this manual has very good pictures
  6. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    sorry to burst your bubble, but unless it was swaped out there is no such thing as a 1973 dana 60 front 1 ton. 77 was the first year, so try to find one of those. sorry, but dont waste a drive to go get it. if you think there is a slim chance, have him send you a pic. I bet $50 it is a big hub 44 and that is why this yunkyard moron thinks it's a 60.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  7. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
  8. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
  9. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    sorry, this damn fuc%$%^$$%$#(*&amp;^% computer is pissin me off.
  10. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    not to sound to stupid what is a big hub dana 44 ?
  11. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    4 bolts in a square pattern holding the steering arm.
    A computer once beat me at chess, but it was no match for me at kick boxing.
    <a target="_blank" href=http://photos.yahoo.com/dana60manual>http://photos.yahoo.com/dana60manual</a>
  12. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    simply a dana 44 with large external hubs, I was not refering to you as a moron, or trying to make you feel stupid, I just think that wrecking yards should know what they are selling you, with a few exceptions, like if it really were a 60 for $100
    a dana 60 also has a large hub sticking out the center of the wheel, but it tapers down. A big hub 44 has little or no taper from the center of the wheel to the lockout. Before I knew any different I thought a big hub 44 was a 60, but once you look at a few, they are unmistakable, Just thinking about a 60 gives me a rise in my pamper.. he he
  13. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    Oh yeah, here's a pic...<a target="_blank" href=http://photos.yahoo.com/bc/dana60manual/vwp?.dir=/Dana+60+Manual&amp;.dnm=page18.jpg&amp;.src=ph&amp;.view=t&amp;.hires=t>Check it out</a> Look at figure 67.
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Forgot to mention that, as 77Chevy said, the steering arm is one of the easiest ways to tell the difference. D60 has the kingpin cap holding the arm with the 4 bolts in a square pattern like this (except this is a modified passenger side for x-over, factory looks the same on the driver's side)
    Sorry these pics are not ideal, they are the best I could find quickly...
    Russ
