D60 High Pinion/HD Dave
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 45acp, Jul 8, 2001.
  1. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    Dave, I would still like to use the High Pinion axle with the ORD Doubler. We talked about this a while back. How hard was it for you to find the Ford axle? I have been looking on the web and at the local junk yards but no luck. It seems that there are more GM D60's Than Ford D60's.
    Bill Hughes
  2. DaveDave
    DaveDave 1/2 ton status
    Feb 8, 2001
    247
    mine come from a f250 hd 78, i paid 500$ can. for complete truck, the only year for the ford dana 60 with king pin is 78-79 f250 hd and 78-79 f350.
    86 and up f350 have ball joint.
    expect to paye 800$ to 1200$ us for one.
    If you want i can look around for one.
  3. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    Dave the 86 to 92 or 93 Fords all had King Pins in them and in 92-93 they went to a Ball joint. The Later ones have spring perches at 37". So if you use the early ones I didn't think you have to change the perches or anything. I could be wrong on that. I thought the early Fords used a 32" spring to spring center but don't quote me on that. Maybe Dave can tell us more about that early axle.
    Donovan
    Bigger is Better
  4. DaveDave
    Feb 8, 2001
    247
    early dana 60(78-79) as 31.5 in center to center same as any chevy front so it is a bolt on instalation, for the shock you have two choice
    1-cut the mount from your 10 bolt and weld it back on the 60 housing. OR
    2-use the stock ford mount with the 76-79 shock tower for a bolt on instalation.
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    What do you (hd-Dave, or anyone else) think of useing a dana 60 R in the rear of a Blazer?
    Twiztid
