d60 inner axle seal procedure
Discussion in 'The Garage' started by stevewix, Mar 23, 2005.
  1. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    any ideas? MUST i remove the carrier?!
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yes you MUST remove the carrier. The seals are pressed in from the inside.
  3. stevewix
    Dec 2, 2004
    83
    oookay! damn. i was afraid of that, anything else you guys would replace while i have it apart besides u-joints and the tube seals?
  4. Esteban86K5
    3,712
    Bakersfield, CA
    I just tore into mine to freshen the grease up after the winter runs i did with it. I found that my kingpin seals were worn/torn, pinion seal was wasted and my nut had backed out. And all my bearings needed a good cleaning. Just inspect everything as your taking it off and cleaning it. Since you taking it almost all the way down i would suggest to at least inspect your kinpin bearing, busshing and seals. Might as well do it all at once instead of doing it twice.
