D60 Inner seal ??'s
Discussion in 'The Garage' started by Masher, Mar 20, 2006.
  1. Masher
    Masher 1/2 ton status
    Mar 7, 2002
    123
    SW Michigan
    I just put 2 new seals in my 60 about 2 seasons ago, and the passenger side is leaking. Its a HP 60 drivers side drop. I have my diff cut and rotated up about 15* so I pretty much fill the diff completely with fluid. Because I do that should I plan on replacing the seals every couple years or does anyone have any tips on installing them and sliding the shafts in?? I greased up the inside of the seal before slipping the shaft in, should I do anything else?? I have also seen some new seals that rotate with the axle?? Are these a better option??
    Thanks for any help and advice.
  2. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    the big rigs use the 2 peice style seals thay last longer.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The after market seals suck, hit up your local Chevy dealer and buy a pair of OEM Chevy seals, the factory seals have a steel piece so that you don't nick or tear the seal while installing the axleshaft and the after market seals don't have this and you might have damaged the seal while installing the axles.
  4. sweetk30
    Nov 1, 2004
    25,536
    533
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
  6. Masher
    Mar 7, 2002
    123
    SW Michigan
    Yeah, those were the new seals I was looking at. How are those working for you readymix?? Should I still look at OE ones?
  7. readymix
    May 30, 2004
    6,706
    26
    I put them in when I installed my Detroit, a little over a year ago. Since then I have had the front shafts in and out a few times and have not developed any leaks. I do make it a point to try to clean the housing before re-installing hte shafts though.
  8. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Not to hijack, but I have seen a lot of detail on replacing the inner seals for the Dana44...I am assuming the process for the Dana 60 is the same. I have been searching and this is generally what I have found, am I fairly accurate?
  9. readymix
    May 30, 2004
    6,706
    26
    Same thing
  10. Masher
    Mar 7, 2002
    123
    SW Michigan
    Thanks, I think I'll give them a shot.
  11. sweetk30
    Nov 1, 2004
    25,536
    533
    easy axle tube cleaning tool is 1 length of threaded rod and 2 nuts and one big washer to fit in tube then cut in half and installed on rod with nuts.
    then run it in tube and turn to pull crap out and repet if needed till all clean.
