D60 installs are a pain in the....
Discussion in 'The Garage' started by sled_dog, Jan 1, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Anyone have tips? having a heck of a time lining up the center pin holes, thanks to toed in springs.
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    You can try using a hi-lift to move the springs apart.
  3. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    When I did mine I did one side at a time. Just losely (sp?) tighten the u-bolts so you can still move the axle fairly easy. Hope that helps a little. /forums/images/graemlins/smirk.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thats what I've been trying and I haven't purchsed a hi lift yet though at the moment I wish I had.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    try a come-along. Losen up the shackle bolts and the spring bolts it will allow more movement.
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Dodge D60? My Chev D60 lined up super easy... /forums/images/graemlins/crazy.gif Dodge D60 the perch width is similar but not exactly the same.
    Rene
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    nope its a chevy for certain. My springs toe in \/ like that and I don't know why but it makes installing axles a pain in the arse.
  8. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    like the other guy said maybe a come along pulling on each spring in the opposite direction...dont know how you would do it and might be a little dangerous though..
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] Especially since my whole frame is up on jackstands /forums/images/graemlins/crazy.gif
  10. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    Definitely be careful. I know how precarious i felt my rig was when on stands swapping the axles.
    I would loosen the spring eye bolts to see if that gives you some movement. You also might want to look into what is causing your springs to toe in so much. How far off are you?
    I also know that I used offset blocks and the "new pin" didn't sit down in the perch so smoothly. I had to grind it (the pin) down a little to fit.
