D60 joints in a D44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Jul 11, 2001.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I was reading on the off-road.com website under off-road/vehicles/Chevy-GMC/S-10 with attitude, that he took a D44 and put the heavier D60 joints in there. The quote "<font color=blue> Dana44 shafts equipped with the larger dana60 joints</font color=blue>" Was I smokin' crack at the time or did it actually say that, and can it be done? Next question. If it can be done to a D44 I would assume it could be done to a Corp 10 bolt right? And how would it be done?
    Heres the link <A target="_blank" HREF=http://www.off-road.com/chevy/feature/nov2000/>http://www.off-road.com/chevy/feature/nov2000/</A>
    If you didn't build it yourself, how can you call it yours.......?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Jesse at High Angle Driveline is making these. Is number is on his site at: <A target="_blank" HREF=http://www.highangledriveline.com>http://www.highangledriveline.com</A>
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  3. Leadfoot
    Nov 28, 2000
    3,112
    From the looks of Jesse's site it shows a new joint machined out of a solid piece of material being used to make a stronger joint, not a D60 joint in place of the D44.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    When he was first doing them, there was a info over on POR about them and he was saying he was using a D60 U-joint and turning down the ends the go into the caps and then making a solid bushing to go inplace of the bearings.
    Maybe he changed and is making them custom now?
  5. Leadfoot
    Nov 28, 2000
    3,112
    Could be my bad too, maybe I misunderstood the write-up. Well anyways, thanks for the info.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    I may have misunderstood also. When I went back and looked at the photos, it does looks custom. I guess we will have to wait until Jesse gets back from Vaca on Monday.
  7. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    They are Dana 60 u-joints ground down so it looks like a Dana 44 u-joint but the journal is around .100-.110" bigger. They are very beefy. He is working on the bushing material that takes the place of the needles.
    Donovan
    Bigger is Better
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What's the point? Won't your shafts fail if you make the joint too strong?
    Tim
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Well, if you're paying for Jesse's u-joints (I think I read somewhere the price will be like $100+ per joint), you've probably already got aftermarket shafts and hub fuses...
    If at first you don't succeed, failure may be your style...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  10. Leadfoot
    Nov 28, 2000
    3,112
    Yes, but I have the upgraded shafts and they don't warranty damage done by a u-joint blowout. I figured the heavier joint is still weaker than the hardened shafts but added insurance against breakage. Breakage can still occur, it's just unlikely, and the shafts are heavier duty to compensate for the heavier duty joint. And no I do not run hub-fuses because I run a lock-right locker, and just like with the detroit, they do not recommend using them with hub fuses. If a fuse goes there is a good chance your locker will too, that is another reason for upgrading the joints. Just as long as I don't here "Ring and Pinion, you are the weakest link........GOODBYE!!!"
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As already mentioned, if you need those heavy duty u-joints you probably already have upgraded shafts. The second reason is that the effective strength of the u-joints is greatly reduced the sharper the wheels are turned. Crank the front wheels to full lock and try to power up a rock face and there's a good chance you will hear snap, crackle, bang..........ask me how I know. This is where a heavier duty u-joint would come in useful.
