D60 kingpin torque
Discussion in 'The Garage' started by odoa3, Mar 23, 2006.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    So, how do you get the correct torque on the kingpins when you are rebuilding them? Factory, they were supposed to have 600 lbs- not sure how I can do that. I have 7/8 allen wrench I used to take them out, so should I just put a cheater on it and get them as tight as I can? This does not seem to be too precise. Any guidance would be helpful.
    Thanks.
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    thats what i'd do, just crank the bastards down. i think thats what most people do without problem;)
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    tractor trailer shops will have a big tourqe wrench for doing big rig tires . ares at work goes to 600 i think. but well over 500 i know .
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    would it work if you made a bar like 3 feet long and attached the allen to on side and put a square hole in the other side to put a normal torque wrench on it. Then say if the bar is 3 feet long you would only have to get the torque wrench to read 200 and the bar would muntiply it to 600 ft-lbs
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Uh....no.
    Just get a 6 ft pipe and put a 100 pounds of pressure on it.
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    uhhh the torque wrench measures the torque AT the head, leverage will just help you get their faster and easier. Snap On, Mac, Matco all have 3/4" torque wrenches that can do 600ft-lbs. Tractor Trailer shop should be able to do it. Me? I would just crank the suckers in. One thing I heard on Pirate I sort of liked, was warm the knuckle a little bit, install the kingpin and crank it down with just a breaker bar(they said ratchet, I'd rather more than that), and as it cools it will lock in. No need to torque.
  7. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Sounds precise to me. When i did mine, There was nothing but a jack handle around so i just used my rear bumper, slipped it over the 7/8 allen and i was done in seconds. Granted the bumper i was using was already in my garage and it was made out of 1/4" 2x4 not capped, weighed 70lbs, and about the width of a full size. In the book i read it said 500-600 so i assumed F**king tight but nothing accurate.
  8. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    this may not be a big help but I'm just donig the same thing now. Here's what I'm using. I had to special order a "long" 7/8" allen and I borrowed a 800ft/lb torque wrench from work. I just cut about an inch and a half off the bottom of the allen. Then I can use the cut piece and a socket to torque it up.
  9. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks for the info guys. I found a 500 pound torque wrench at a rental shop. I guess I can use that then a "touch" more. Problem now is finding a 3/4 drive 7/8 socket. I like the heating idea.
    What happens if you over tighten it? Steering would just be too tight, correct?
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no, you just may never get it back out of the knuckle without destroying the knuckle. If its too loose of course it could work its way out, and that would simply be bad.
