D60 Leaf Spring U Bolt Question
Discussion in 'The Garage' started by CDA 455, Jan 25, 2007.
  1. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    On the passenger side leaf spring bolt up; what's the best way to fasten the inside of the spring plate? Bolts? Studs?
    Would 5/8-11, 3" grade 8 bolt be good enough? Locktite them?
    And can you point me in the direction to purchase the hard wear if studs are needed?
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    There was a big post about this a while back. I run grade 8 bolts on mine. So far so good. You can get the studs when you buy a ubolt kit. Not sure if you can buy them on thier own.
  3. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    Yes, many people use bolts. I found some GradeB7 studs at the local bolt shop.
    I recently went with a kit from BTF that includes new studs. They are long for thick leaf packs. This is mine with 52's up front:
  4. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    Ahhhh, Thanks for the pic and info :bow: :bow: :bow: :bow: :bow: :bow: :bow: !
    What's the measurement of the fastening device? <----Carefully worded to ward off the pranksters :D :haha: !!
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Oh really?
  6. CDA 455
    Jun 2, 2006
    8,598
    43rd State
    :confused: ???
  7. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    all of them i have played with are grd 5 stock from factory. and i run bolts with neverseize on them as i live in the rust belt. and no problems ever for me. i just install what ever i am puting in for lift. then add top plate. i use a screw driver in to the plate hole untill it hits bottom. i then check the length. and remove about 1/4-1/2 or the length as the holes are tapered at bottom and bolt is flat. never had a problem yet.
