D60 leaking gear oil out of passenger tube
Discussion in 'The Garage' started by Okiemuddog, Mar 21, 2004.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Okay, I am going to show my ignorance, where is the oil seal at /forums/images/graemlins/dunno.gif? Does any one have the part number and what is involved in the replacement? I checked at work and the only seal I can get is the wheel seal for the back of the hub /forums/images/graemlins/doah.gif.
    TIA,
    Krennen
  2. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    If it is anything like a 44 then you have to pull the carrier out. It is pressed in behind the Carrier bearings. I don't have any part #'s.
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Inner wheel seal...have to remove the carrier to replace them.
    As far as part number, I'll leave that to someone else. /forums/images/graemlins/smirk.gif
  4. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Make sure to get this seal from a dealer because the GM seal has a guide collar that helps line up the shaft. You might find that your shafts have been grooved by running on dirty seal. Good luck /forums/images/graemlins/thumb.gif
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    only problem with buying rubber parts form places like GM shelves is that they might have been on shelf so long that they would be no good nowadays,
  6. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I talked to Sapper and he told me that my axles were originally the "Generals" (Joel). After talking with him he said that my D60 inner seals were leaking too but he never got to replace the seals and neither did Tyler. I went to Autozone and bought new inner seals and bearings. Both were Timken brand. Bearing # Set 38 and the seals are #2081. If you find I was given the wrong ones let me know. I haven't changed them out yet as I'm still deciding on what locker I want. Already have the 35 spline stubs and hubs
  7. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Why are you replaceing the bearing?
    Make sure you got the "Inner Axle seal" not the "inner wheel seal"
    AFAIK, all inner axle seal for D60 have the guide to allow the axle to seat properly without jacking up the seal...
    Chris
  8. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Why am I replacing the bearing? ...why not? Since it's gonna be apart and has unknown miles on it, it's worth a few extra bucks for my piece of mind knowing everything inside is new
  9. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Are you planning on settin gup your gears again? if you just keep the old bearing on, you just pop the carrier out and repace the seal and pop the carrier back in..One you pull those bearings off the carrier, you are going to "need" to reset the gears and back lash...I say "need" b/c you probably can get away with not doing it but you really should...There is a reason you need to take your time to set up gears when you put all new bearings on the pinion and carrier.
    If you are planning on a locker, DO IT NOW. Just get a locker and a master install kit and then set up the gears and run it. Aftre replacing the seal of course
    Chris
  10. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Hmmm..didn't realize setting up again was part of the process. thanks
  11. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    if I were you, I wouldn't bother replacing the bearings unless they were known to be bad or you were installing a locker or swapping gears...I am keeping the stock gears in my D60 (4.56) but I have a detroit sitting in the garage and just need and install kit to setem up...
  12. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You will ahve to pull out the short side axle, before you can remove the carrier.
    I would be sort of silly to only replace the carrier bearings and not all of them. Usually you can just do a rebearing and the R and P will not change, so theres really no need to worry about screwing everyitng up. Same if you put in a locker, the R and P shouldnt change.
  13. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Quick someone call the FAA, I need an air marshal, because my post has been HIJACKED /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  14. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    You can get them from www.partsamerica.com it is chicago rawhide part number 15692. The last time I bought the real spicers and it was the exact same part in different boxes.
    To change them you have to:
    1) pull the hubs, spindles, and the axle shafts (both).
    2) take the carrier out (might have to pry -- be careful its heavy).
    3) knock out the old ones with a broom stick or something through the axle tube.
    4) Finally you have to drive the new seals in without damaging them. Some people put a bunch of extensions and a socket through the axle tube to pound it in but I just use a small sledge and a large socket or puck.
    I would not replace the carrier bearings unless there is something wrong with them. It would definately be in your best interest to check the preload and backlash after pressing on new carrier bearings.
  15. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    20 year old bearings/races, matching todays batch
    will usually be different. /forums/images/graemlins/smile.gif
  16. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    HAHAHA..sorry man. I was just trying to help /forums/images/graemlins/whistling.gif
    I'll make it up to ya /forums/images/graemlins/waytogo.gif
  17. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
