D60 Lift Question
Discussion in 'The Garage' started by scrappy88, Jul 21, 2003.
  1. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I'm sure this has been asked before but I searched and couldn't find anything conclusive. I need to know how much a Dana 60 would "lift" the front end of the truck when compared to a 10 bolt. I've seen anything from 1/2" up to 1 1/4". Does anyone know? I'm trying to plan out what springs I will need and I'd like to factor in the amount of lift the axle itself would give. Thanks! /forums/images/graemlins/smile.gif
  2. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    I've been told 3/4" over a 10 bolt.
  3. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    An inch.
  4. TOMER
    TOMER Registered Member
    Sep 20, 2002
    38
    Israel
    MY DANA 60 HAVE 3/4" OVER THE 10 BOLT.
  5. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    I'll figure for 1 inch then. Thanks guys! /forums/images/graemlins/thumb.gif
  6. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Sounds like you already got a close enough answer but....
    there are two parts to the equation: The axletube diameters themselves, and the perch height.
    If you could measure the total distance from the bottom of the axle tube to the top of the perch on each axle, then factor out the difference in axletube diameters....you could get it pretty exact.
    I know I got some unwanted lift when I swapped the D44 for the D60....it got even worse when I added the 6* shims to correct my pinion angles....... /forums/images/graemlins/blush.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    There was a 3/4" difference when I went from 10 bolt to D60.
