d60 locker choices
Discussion in 'The Garage' started by TX Mudder, Nov 26, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    List of D60 locker choices
    That's what I see as available.
    Trac loc and Power loc- LSDs, so probably no good.
    ARB - I don't have that much money to put into it.
    Lockright - I hear these break a lot.
    No slip - Don't know too much about it, have searched without any good info.
    Spool - Out, I drive on the streets.
    Detroit - about the only thing left, and bulletproof.
    Is that pretty much the gist of d60 locker choices?
    -- Mike
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The Power-Lock is a VERY good LSD... It has a funky wedge-action with the cross-pin that makes it work much better than a basic clutch-pack LSD. Nice thing is its not clunky, making it good for a steering axle.
    The problem is finding one for a Dana 60 35-spline application /forums/images/graemlins/rolleyes.gif
  3. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I didn't think about that - which ones are for 35 spline inners and which are only for inferior inners.
    Hmmm...
    -- Mike
  4. u2slow
    May 9, 2001
    2,217
    BC Canada
    This is unverified....
    Somebody told me you can swap the 35-spline side gears from a D70 power-lock into a a 16 or 30-spline D60 powerlock.
    Two problems I have with that scenario:
    1. Finding a Dana 70 power-lok /forums/images/graemlins/rolleyes.gif
    2. I don't think a 35-spline shaft fits into the 16/30 spline case. Could bore it out - if there's enough material (same bearing size? who knows?) /forums/images/graemlins/confused.gif
    Also heard that the power-lok came in full-floater applications, whereas trac-lok is for semi-floaters. Hmmm... I think one of the few 35-spline Dana 60 full-floaters is an E350 SRW.... anyone know?
    Sorry, more questions than answers /forums/images/graemlins/grin.gif
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I recommend the Lock-right---belive it or not ive heard these hold up very well in 60's (even better than detroits. i have one in mine and right now i dont whell it toooo hard bit i did break a hub and the locker is fine---you will most likly pop the detroit in this senario (sp?)
  6. im getting the powerlock in my front 60, after talking to the shop, i was convinced that was what i need, since its a daily driver, and willl need 4x4 on street when driving in snow.
  7. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I agree with SCOOBYDANN. I have a Lock-Rite running a mild 355 small block, one-ton axles, and 39.5" TSLs. I've been really hard on it for about 10 months and have yet to break it. I recommend it as a viable alternative to a Detroit Locker. Just my $.02.
    Will
