D60 locker question
Discussion in 'The Garage' started by muddybuddy, Dec 4, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    will a detroit that was for 4.10 gears, work with 5.13 gears? or are they different?
    thanks
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    the carrier size is smaller but if you get 5.13 thick gears it will not be a problem :D
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    yes if you get the thick gears you can use the 4:10 detroit :D
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Maybe somebody can post a link for thick, standard-cut, Dana 60 gears? :whistle:
    You can use a ring gear spacer to put 5.13s on the 4.10-down Detroit. The ratio break is 4.10/4.56 for the diff cases.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Exactly :waytogo: ... there are NO thick gears for a standard rotation D60. You either have to have the correct locker/carrier, or use a spacer.
