D60 Lockouts
Discussion in 'The Garage' started by ProJunkRacing, Jan 9, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    I just pulled apart my lockouts and have some broken inards i want to get flanges but do they make them for 30 spline applications or what would you all reccomend
  2. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    im pretty sure they make them for 30 spline... check out pirate, htere are usually a few in the for sale section
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    jus bought new 30spl warn premo's for $165 from porc
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i have a set of stock gm/dana 30 spl flanges. thay did use them.
  5. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    well i meant like the warn flanges it will be welded with x over and hydro assit and want strong but not 35 spline yet
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Welded and slugs I see ram assist in your future, as well as some busted stubs.:D
    Ira
  7. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
  8. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i see they have them for 211 but what is worth it hubs or slugs?
    181 for warn d60 hubs
  9. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    As already mentioned factory 30-spline flanges were pretty common and you could probably find some around with all of the people switching to either hubs or 35-spline stuff.
    I doubt you will ever break a 30-spline factory flange.....it's a single solid piece of metal and has to be a lot stronger than any locking hub out there. You will definitely break a Spicer 30-spline stubshaft before the flange. I've personally broke 2 Spicer 30-spline stubs and they did not phase the factory flanges. Another friend (78Buford) is running factory flanges that were broached out to 35-spline and has had no problems.
  10. sandawgk5
    Oct 28, 2003
    6,881
    Where would one look to find a set of factory 30 spline flanges?:D
    Ira
  11. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    My D60 out of a '77 truck had factory flanges. I remember seeing several sets on ebay in the past, but otherwise I haven't really been searching for any.
  12. sandawgk5
    Oct 28, 2003
    6,881
    Thanks I will check E-bay
    Ira
  13. 79k20350
    Nov 22, 2004
    7,757
    Ct
    dude, just go hubs, ita nice to have the selectability, especially if its driven on the street. 30 spline hubs are plenty strong (stronger than 35) and its cheaper. looks like an easy decision to me.
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    bro, i bought d60 warn premiums for $165....
  15. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    where?
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    performance offroad center. normally they are like $200. i got the quote off pirate and they said $165 (discount for bein on pirate). so when u order tell them ur from pirate and give them ur username and you are good to go.
  17. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i got warn premiums still in packaging for $90:D just check the forsale sections more often
  18. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    damn, you got really lucky there. u practically stole them!
  19. jekbrown
    May 19, 2001
    45,029
    361
    Vancouver, WA, USA
    less splines is a good thing now?! Most good aftermarket flanges have much more contact area between the flange and the axle than your average hub or warn-style thinner flanges... they should be stronger.
    j
  20. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    explain
