d60 luckout hub problems?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by skyyk5, Jan 20, 2007.
  1. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    i just took out my plow truck, in 4 wheel the front tires don't spin. gotta be the lockouts right? it was stuck on ice and i saw the driveshaft spin and the one axel shaft spinning by the knuckle. it has the factory lockouts on it. can they be frozen?
  2. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    The exact same thing just happened to me. I ended up jacking up the front end and locking the hubs to see which one didn't engage. The plastic knob on the driverside ended up being stripped out a bit. Instead of try and fix it, I just bought a set of Warn premiums. Now I don't have to worry about it.
    For a quick fix though, you might be able to take the hub off, engage it and then re-install it. Not ideal, but it will probably get you through winter.
  3. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    if you don't mind what did those hubs run you. and thanks for the help
  4. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I got them for just under $200 shipped on e-bay. 38826 is the part number I believe.
  5. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    thanks!
  6. dbozman
    dbozman 1/2 ton status
    Nov 11, 2006
    115
    Phoenix
    It's worth it just to spring for the Warn hubs. You could disassemble your existing ones and possibly fix them, but the Warns are SO much better.
    If you've got stock 30-spline outers, you could probably score a set cheap from one of the rockcrawler guys who've upgraded to 35-spline outers. Check Pirate.
    d
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Got a pic of your "stock" hubs? If I like what I see in the pic, I will buy them from you for parts.
  8. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    they are the full turn ones. i can get a pic tommorrow.
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ok, I'm still interested.
  10. skyyk5
    Jan 2, 2007
    1,537
    N.E. PA
    Fixed the truck today. The slidding ring was all gummed up and would not engage. It works now! Going to change hubs this spring anyway. So thatK30guy, If you still want them, If you can wait, they work.
  11. JIMMY76
    JIMMY76 1/2 ton status
    Dec 28, 2004
    209
    HAUGHTON,LA
    autozone had mile marker stainless steels all metal 1/4 turn on the self for 180
