D60 or 14sf?
Discussion in 'The Garage' started by dirtwarrior17, Mar 15, 2005.
  1. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    the d60 is probably a little bit stronger due to ring gear size but what are the axle shaft like compared to the 14bsf?
    Also which has more ground clearence?
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Dana 60 out of what? 30 spline SF? 30 spline FF? 35 spline SF?
    The only real advantage i see to a 60 is if you are staying SF, then the 35 spline SF would be a stronger shaft along with not having C-clips. But good luck finding one of those, they arent exactly common.
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    the D60 would be stronger if its full-float.
  4. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
  5. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Only if you step up to 35 spline. The 30spline, even in full float, is weak.
  6. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Thats just a housing, you still have to fill it with gears and shafts. And since its just a regular 60, i dont think you can get it to accept 35spline SF parts, somebody will have to confirm this, but thats what i recall. I go with a 14bSF over a 30 spline 60, 35 spline is debatable IMHO.
    No offense, but why would you pay that much for a housing anyway? You can get a rear 60 in a junkyard for dirt cheap, they are nowhere near the cost of a front.
  7. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    i dunno.... i saw it all shiny and said i want it... also looks like it has disc brakes.
    junkyard is probably where I'll end up.
  8. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Strength of a axle would be determined by the axle shafts and pinion size. Ring gears usually fail because the pinion gear started to fail......
  9. dark eternal
    dark eternal Registered Member
    Jan 15, 2004
    22
    Dallas, Tx
    the full float design is far superior Ill leave it at that.
  10. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    so to repeat my originaly question which has more ground clearence?
    d60 or a 14sf?
    If there are different size 60's then i'm talking about the one with the most clearence.
  11. dark eternal
    Jan 15, 2004
    22
    Dallas, Tx
    all 60 housings are the same pretty much, not sure if it or the sf has more clearence though. Ive worked on both in person, im thinking they are real close.
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    go with a 14 bolt FF or SF it doesnt matter, its a direct bolt in. way cheaper and easier that way. most people here run them without issues.
  13. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Same ring gear, same pumpkin, same clearance.
  14. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    could i get the 14sf shaved somehow? what all is invlovled in it? If i can pull it off with a sawzall and a custom cover then i might do it myself.
  15. blazerpro79
    blazerpro79 1/2 ton status
    Jan 4, 2005
    528
    Simi Valley, CA
    d60 has more clearance
  16. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Yep you are correct, I wouldn't even concider a semi floater axle if there was a full float avail.
  17. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Rock a 14bFF and be done with it, you'll never worry about bustin a rear axle again.
