D60 Overhaul
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadCad, Aug 6, 2002.
  1. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    Does anyone have any links that show a D60 overhaul/teardown? It would be nice to have a visual referance if needed.
    Opinions please:
    If you are in the middle of a brake job and discover one of your front calipers/cylinders is shot and needs replacing, do you replace both while it's all torn apart or do you reuse and wait for the other one to go bad?
    thanks in advance
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I always replace the calipers as a pair, cylinders I would be OK replacing one at a time. The only tear down instructions I've found for the D60 is the manual that you can find in the tech section here on CK5.</font color>
  3. BigBadCad
    Dec 18, 2001
    109
    minneapolis, mn
    Alright..I priced some loaded(Raybestos semi-metallic) calipers at Checker for $46. Any opinion on the pads? Would I be better off buying an unloaded calipers for $25 and loading it with a differant pad? I am willing to pay a little extra for a superior product.
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I used the Raybestos pads and they worked fine. Of course I wear pads out in like 5k miles... Sand, mud, and 38s are hard on those little buggers /forums/images/icons/wink.gif </font color>
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what is "shot"?
    is the piston scored badly? or just the seal worn out?
    if the piston is in good condition just replace the seals
    raybestos part #
    piston dps85051
    seal kit wk806
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    I'm about to embark on the D60 rebuild journey in the next few days.... parts have been ordered, and I can take pics as I go.
    I am by no means an expert, but maybe that will make it better....I don't make many assumptions about what you might know (or don't know) about the steps involved.
    I'll be doing the complete outer areas...bearing sets, kingpin rebuild, u-joints, hubs, etc. I'm hoping NOT to dismantle the gears &amp; carrier, or replace those inner fluid seals though.......
  7. BigBadCad
    Dec 18, 2001
    109
    minneapolis, mn
    The seal has disintegrated and the piston is seized. I've decided to replace both calipers and be done with it. Now I just have to figure out how to tear it down.
  8. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    yeh Greg let us know how it goes cause i've got to do the same exact thing. /forums/images/icons/shocked.gif
  9. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    If you do have to change inner tube seal, use the gm part #462857. It has a nifty steel guide collar to help put shafts in. My shafts came out covered in goopy crud, so I had to replace seals.
