D60 parts
Discussion in 'The Garage' started by dammit32, Jan 18, 2003.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    I bought a matched pair of CUCV military surplus axles but I wont be picking them up for a week or two. I was pondering some parts problems...
    Spring plates ...can I use my old ones?
    Brake lines...Does the D60 use a banjo fitting like the 3/4 ton?
    U-bolts...size of the axle tube?? length of the u-bolts with 4" Skyjacker springs?
    Conversion u-joint...I have one on the rear already but the front would be different because they have internal type clips on them...NAPA part #?
    Shock mounts...will they be in a different location?
    Spring Pads...will they need to be moved?
    The sell claims the axles will be 1" shorter thean my 3/4 ton axle...is this true? will this cause me problems?
    I guesss I had quite a few questions LOL
    Any help is much apreciated /forums/images/graemlins/smile.gif
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Did you buy them from that guy in Mass who sells them on ebay?
    If you have a 10 bolt in the front you can use your existing brake lines. D44 front uses different ends on the calipers.
    You will need 3 u bolts and either 2 studs or grade 8 bolts. Not sure on the length you need. I got mine from ORD when I did my swap since I needed some some other parts. You will need the spring plates from the Dana 60. You can get the driver side to work from a 10 bolt axle but you need the D60 passenger side one. Also for the rear you would want to use your 3/4 ton plates for the u bolts. The axle is the same width as your 3/4 ton axle, just the spring pads and shock mounts will need to be moved.
    U joint on the front should bolt right up to the D60. I only needed a Napa 447 to bolt the driveshaft to the rear 14ff.
    Hope this helps.
  3. dammit32
    Jul 20, 2002
    365
    Maine
    thats weird the u joint isnt larger in the front /forums/images/graemlins/confused.gif
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yeah, it uses the same 1310 ujoint that the 1/2 tons axles do. There are 1350 yokes available everywhere for about $50.
    -- Mike
