D60 Pinion oil seal
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TheGeneral, Jan 9, 2002.
  1. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Getting ready to do D60 Pinion oil seal. Anything out of the unusual to look for. Mark pinion, flange, pinion nut location, current torque in in-lbs, remove nut, washer, flange,pry seal, clean, oil new seal and install in reverse order?
    If you ain't hurt, you ain't playin' hard enough.
    The General
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Sound about right , just remember that in-lbs reading is Dymanic(rotating), not Static(stationary).
    Good luck
