D60 pinion yoke ?
Discussion in 'The Garage' started by FWP, Oct 20, 2005.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I'm changing out my 1310 for a 1350 yoke. It's just rattle the old nut off, and rattle it back on to 230-300 ft/lbs, right?
    Am I missing anything?
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    You know it is not just that easy. :doah:
    Hint Pinion bearing pre-load. :D
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, I thought D60s were shimmed pinions and just torqued down. C14FF has a crush sleeve and has to be carefully monitored for pinion bearing pre-load, but I didn't think that applied to a D60 (or most any common Dana axle).
  4. fwdjunky
    fwdjunky 1/2 ton status
    Oct 12, 2003
    499
    Maricopa, AZ
    Russ has it. The D60 uses shims to set pinion preload. You should be able to just retorque the pinion nut and be fine. I would suggest using a new pinion nut or strong lock-tite just for peace of mind.
  5. jeff101
    jeff101 Registered Member
    May 1, 2004
    24
    Lander,Wyoming
    I just did exactly that same thang to my D60 and havent had any probs yet only have approx. 50mi. w/warn drive flanges.
    JEFF.
    72 TRUGGY
  6. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Thank you gents. That was my figuring :D
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Please :rolleyes: Hint. There is no crush sleeve :wink1:
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Is a Dana 30 front the same way? Is it a shimed pinion? I need to change the pinion seal in my CJ5 and never did it because I thought it was a crush sleeve like a 14bff and I would F-it up.
    Harley
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    I don't know Harley. Jeeps have always mystified me :haha: Tye might know, I'll ask next time I talk to him.
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    AFAIK all Dana axles use shims for pinion preload.
  11. Executioner
    Feb 22, 2000
    1,530
    Not ture, there is at least one Dana axle that uses a Crush sleeve
    for pinion pre-load.
  12. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Not true. The newer Dana 60s use a crush sleeve. All the GM 44s and 60s should have shims though.
  13. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Some have crush sleeves some have shims. 70s too.
