D60, Power Lock, or Lock Right
Discussion in 'The Garage' started by SUBFAN, Oct 8, 2005.
  1. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Which one is stronger? I have a Power Lock that could be installed up front, or should I go with a Lock Right?
    If I do not use the P/L up front, that axle will prolly find it's way into the DD. (front/rear 60's)
    Mostly mud application, maybe a feww rocky trails thrown in. I need to buy new gears for the 60 as I have found a 5.13 geared 14FF :woot:
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    I'd say that by comparing the 2, the powerlock carrier is actually stronger than the stock open carrier (which the lockright would go in).
    However, I have not heard of too many actual carriers breaking.
    Unless you meant traction wise, the lockright is actually an auto locker and the powerlock is a clutch posi.
  3. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Stronger = to resist breaking....
    A P/L can be set up pretty tight. Just trying to decide on whether to use it in a front or rear application....
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Probably less wear/tear and shock loading/unloading on the u-joints & axle shafts with the Powr-Lock. That would be one reason to use in the front.
    Also, drive flanges or lockouts? I would assume flanges are okay with the Powr-Lock... but with a Lock-Right? :thinking:
  5. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Good point....
    It has lockouts now, but never thought about that....
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    But flanges in a DD = less fuel mileage since everything up front is always spinning.
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    The one getting the front 60 is retired from DD useage. The P/L would be cool in the rear 60 of the DD, just trying to decide if it should go into the front of the play truck or not....
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'd definetally put a locker in the front of a play rig. PL in the rear of a DD doesn't sound like a bad idea at all.
