D60 question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by talldogg, Jul 26, 2001.
  1. talldogg
    talldogg 1/2 ton status
    Jul 26, 2000
    754
    San Diego, CA
    Couple questions on the front Dana 60.
    What applications had it? Truck/Year?
    Is the dually version worth looking for? I remember reading that it wasn't worth converting money wise.
    What are dead give aways in ID'ing one to make sure you're not looking at a 8 lug D44?
    Thanks guys, I want to make sure I know what I'm dealing with in case I come across one as I'm now spending more time on the Blazer.
    It's not what you buy, it's what you build!
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    1976 up to 87 K30's, Crew cab and cab and chassis from 88-90/91 had them. Dead give aways are kingpins instead of balljoints, the steering arm is held on with a 4 bolts in a square pattern whereas lesser axles held the arm with three studs and nuts in a 'C' shaped pattern. Plus most D60's had a '60' marked on the pumpkin.
    Sorry it should have been post '76.
    If you didn't build it yourself, how can you call it yours.......?<P ID="edit"><FONT class="small">Edited by Leadfoot on 07/27/01 08:57 AM.</FONT></P>
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Actually, it's 77' to 87' K30s and 91' crewcabs that had the 60 front. But like Lead said....all those are good characteristics. That and they're just so much freakin bigger!![​IMG]
    Boss
    89' 1 TON of FUN K5
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Also, the axle is held to the springs by 3 u-bolts, not 4 like the D44 or 10B. The D60 uses 2 studs or bolts to fit into the differential housing.
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  5. talldogg
    Jul 26, 2000
    754
    San Diego, CA
    Man you guys rule!
    First of all, what's a kingpin?????? Also is the duallie version the same as a single wheel version, except for the rim?????
