d60 rear disc
Discussion in 'The Garage' started by 69K5, Jan 21, 2004.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    is there a diffrence in d60 rear disc brackets and 14ff/ eaton rear disc brackets? anyone have a pic of there set up on a d60. didnt see one over on AZ
    thanks
    69k5
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Send a PM to SUBFAN.....he is in the process of putting disks on a rear D60.
    Also....PM jms....he has disks on his rear D60. /forums/images/graemlins/thumb.gif
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    beast 388
    thanks. i am gonna pm them. i did some more searching and found out the center holes is biggre. i still dont understand why on dodge brackets people cut off the bottom and only have 3 bolt holes. while chevy and ford d60 have all 4?
    thanlks again
    69k5
  4. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The rear D60 that I had (that SUBFAN now has) has 7 holes for backing plate mounting.....a little different than the Furd & Dodge D60's.
    Here is a link to Blackbird's Custom Trucks. They sells a rear disk kit for Chevy D60 rears. /forums/images/graemlins/thumb.gif
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    www.azkickin.com made the disc brake kit for my D60.
    Oh... and it came from a Dodge.
    Marv
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Beast388 is correct. The GM D60 has 7 mounting bolts, and the Ford has 4.
    I ordered one for the Ford housing, but changed my mind and used the GM one instead. I need to get off my but and send them back and get the right one. Let me know if you want to use the GM housing, and I will send my kit back and the pattern for it. I cut the center out of the backing plate, because I knew I could not draw one correctly /forums/images/graemlins/tongue.gif
    That way everyone that gets one will have a correct fit /forums/images/graemlins/thumb.gif
  7. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    The Dodge plates mount on the inside of the axle flange so the bottom has to be cut away to allow the plate to slip over the axle and behind the flange. /forums/images/graemlins/thumb.gif
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    beast
    i looked at blackbirds thats how i saw the difference in the 3 mounts. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gifthanks again for the help.
    Marv
    can i have it???? /forums/images/graemlins/smile.gif seriously though thats what i needed. do you know what the width on the dodge rear end compared to the front end? just wandering if i was gonna need any wheel spacers. /forums/images/graemlins/confused.gif
    sub fan
    i returned your pm
    45ACP
    thanks for clearing that up. /forums/images/graemlins/thumb.gif i was hoping you would see this and answer.
    JMS
    i like those brackets. i dont have to worry about rocks, just vines and tree branches in the mud. It always amazes me how clean your shop is in the pics. /forums/images/graemlins/grin.gif
    thanks again to everybody /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
    69k5
