D60 Rotors
Discussion in 'The Garage' started by ProJunkRacing, Jan 14, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    How much did you guys pay for dually Rotor's in the front
    I called autozone and they are like 99 bucks a pop
    wtf i don't want to spend that much on rotors any better places to find them ?
    are single wheel rotors the same price?
    also as far as calipers goes does it matter if it is drw?
  2. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    is 83 a pop cheap for them i found that price on carparts.com supposed to be great prices
    and 59 a piece for loaded caliper
  3. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    The SRW and DRW rotors are the same, only the hubs are different. The price is just for the rotors. You would need to remove the hub and install it on the new rotors. Dont know an actual price, but that sounds about right for this application.
    GMPartsdirect seems to be the ceapest for SRW hub/rotor assembly around. I paid $114.72 each. But they make the money back on shipping and handling ($80.00). Part # is 15635530.
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    NO. DRW use bolts to bolt the rotor to the hub. SRW rotors use the wheel studs and are pressed from the back of the rotor to the hub.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    That is correct. that means drw have smaller diameter holes than srw. thats why when switching from drw to srw you can use your stock rotors by drilling them out. i got loaded calipers for 50 a piece at napa. they wanted like 60 a pop for rotors.
  6. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i just cut my rotors see how it goes they dont seem that bad and didn't want to pay that much
  7. randy88k5
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Yeah, I didnt think about the stud sizes. I just matched up the rotor sizes when I had them side by side. I thought they were the same. My bad.
  8. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    wow I bought mine last year to do the rear for 50euros a pair on ebay:woot: . I finally got a good deal. sorry they are so expensive now :doah:
  9. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    You think $99 a piece is expensive, just wait until you have to buy a set of rear drums. You will be looking at close to $150 a piece (with tax and every thing).
  10. beater74
    May 29, 2001
    1,749
    atlanta
    DRW rotors can be used IF the stud holes are enlagered to 21/32
  11. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    that my friend is why you do a rear disk swap
    i think i got
    60 in for brackets
    30 a pop for rotors times x2
    26 a pop for calipers x2
    then hoses not sure
    and 31 for pads alot cheaper in the long run and i had cores for calipers so no charge
  12. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    After I buying a set of new drums for one of my 1 tons, that is exactly what came to my mind.
  13. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    why would you even buy them before considering rear disk
  14. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    because it was so much easier to do...project wise. I already had all new wheel cylinders and brake shoe hardware from a recent rear brake job. All I needed to make the rear brakes tits, was to buy a quality set of rear shoes, some new drums, and slap it on.
  15. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    yeah i am going to sell the truck now just decided
