D60: Seals behind the spindle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nvrenuf, Mar 7, 2002.
  1. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    I'm having an on going problem of water getting into my front hubs. I need your suggestions and help to make sure I'm putting this together correctly.
    I repacked my front bearings in Sept. using new wheel seals and I put a small bead of RTV (in addition to the original o-ring) on the locking hub cap to help create a good seal between the bearing hub and the locking hub cap. My problem is that now the snap rings, locking hub mechanism and axle are either corroded or rusty. All of these parts were in clean / excellent shape when I put it together. Due to transmission failure the truck has been in the mud only twice (only sat stuck in the mud once for approx. 15 minutes) and has been sitting most of the last 4 months.
    I'm thinking that the water must be getting in through the seals between the spindle and axle shaft or coming in around the knob on the locking hub.
    1) How likely do you think it would be for it to come in around the knob?
    2) Just to make sure I'm doing it correctly, how do you install the seals behind the spindle? Which side pointing out? Do you put a little grease on them to keep them soft?
    Thanks in advance for all the help!!
  2. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Anybody.....?
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    <a target="_blank" href=http://www.gohumvee.com/images/Tech/Dana%2060%20HTML/Image19>http://www.gohumvee.com/images/Tech/Dana%2060%20HTML/Image19</a>
    sorry I wasnt 100% so i just lookie loo'd and carried on
    I havent had a water infiltration problem
    I would look to the same areas you are doing
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    and yes i always give seal surfaces a bit of grease
    doubt it makes a difference as it will dry in short time and when still greasy will hold grit but i still do it
