D60 spindal torque, need them faste. thanks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Apr 25, 2003.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    im not talking about the two flat nuts holding the hub on, im talking about the 6 nuts holding the spindal on the knuckle.
    i did a search.
    and i looked in the D60 manual. not there on ethier count.
    anybody?
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    What diameter are they - I'm at work but can look up the standard torque for steel bolts of that size if you want.
  3. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    1/2 inch. where are you looking it up at? for future use.
    thanks.
    grant
  4. azblazor
    May 5, 2001
    1,953
    I would go to the following places - the torque for a 1/2 in coarse thread ranges from 47 ft-lbs for Low carbon steel to 119 for Grade 8 bolts, The nuts and bolts section referenced below also has a section to help you identify the grade.
    Go here and look under nuts and bolts: POR tech
    and here for Dana 60 Info: POR Dana 60 tech
  5. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    cool beans dude. thanks alot
    grant
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    65 ft/lbs per GM manual...
  7. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    33 ftlbs on 80 model D60 and 65 on 81 to 87.
    i went and bought a chiltons for the truck my 60 came out of.
    thanks guys. grant
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    33 on the 80? /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif What, did it have aluminum bolts or something?
    Edit: BTW, I've got manuals, if you need info, give me a ring...
