D60 spindle nut socket
Discussion in 'The Garage' started by broc944, May 11, 2006.
  1. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Is it me or is the spindle nut on a D60 a different size then other front axles. I have two different spindle nut sockets and neither of them seem to fit. Yes I know I should do a search on this, but it has been a really long day, and I just need to know if I need to stop art NAPA on the way home tomorrow:D .
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    different than a 44 or a 10B yes.
  3. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    Thank you very much, thats all I needed to know.
  4. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I had a Dana 60 hub socket..... but it had six prongs. Perhaps it was for Fords or something. Had to go buy a Chevy 4 prong socket.
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    My Dana 60 needed a 6-prong one. It's bigger in diameter than the 4-prong 1/2T and 3/4T one.
    Mike
  6. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I jsut went through this last week and I needed a four pronger with the prongs on the inside instead of at the end. The lable on the package said it was for Ford F350 1 -Ton. Another guy on here told me he had the same experience. I am running military axles, maybe that's why
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have a socket that has the 4 prongs on the inside and 6 prongs on the end so it will do either style of nuts. :thumb:
  8. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    The Dana 60 uses the same Inner and outer bearings and races, spindle nuts as the 14 bolt 10.5"
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Care to share where you got that?
  10. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have no idea where i got it. I have 3 different sockets which will cover and D44, 10 bolt, 14 bolt, or D60. I could always look and find out what brand it is for you though. I know one of the sockets i have is either a Mac or Snap-on.
  11. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    Not sure about that, since the socket I use on my 14b did not fit my D60. Stopped at NAPA on the way home and picked up one for a 1 ton, which fit and is different then the socket I use for my 14B.
  12. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Napa part#775-9027 says it fits Dana 50 ifs and dana 60 F-350 1985 to 1997 AND 1987 GM 30 series frontends Mine is a 4 prong have not used it yet so not sure if it will fit my 78 model Dana 60:(
  13. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    That would be the one I purchased yesterday, and it fit perfectly.
  14. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    What year is your 60??
  15. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    It is a 89 according to the yard I got it from.
  16. yellowK20
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Okay well I guess I better try mine then I lost my other socket my both of my 60's came from 78 model trucks
  17. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    He is correct, D60 and 14FF use the same inner and outer bearings but there are 2 different styles of spindle nuts.
  18. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    OK that makes more sense, I actually learned something today! Thanks.
  19. DaPlumber
    Apr 4, 2003
    212
    Holland Oh.
    I have the newer key-way style from a 14ff on the front 60 and the rear 14ff. I like being able to use the same socket for the front and the rear axles.
  20. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Same here, I got a few extra spindle nuts the last time I was at the junk yard and put them on my front 60, one socket front and rear. The wheel bearings are the same for sure, I have a few from each axle out and they are teh same size. I have also heard, though I dont have personal experience with it yet because I havent gotten into the rear of my crew cab. But I understand that the wheel bearings for the rear 60's and dana 70's are also the same. Which will be nice if its true because then I can have wheel bearings for all the axles under my trucks and not have to worry about which ones are for which axle. 14, 60, or a 70.:waytogo:
