D60 spring bolts... red lock tight, blue loc tight or lock washers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Sep 16, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    On my D60 spring bolts should I use red loc tight, blue loc tight, lock washer or nothing? Also what should I torque them to? Thanks!
  2. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    i use blue loctite and flat washer /forums/images/icons/wink.gif torque i think 180
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    never use red
    I would say nothing as you have to retorque them
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    WOW!!! /forums/images/icons/shocked.gif 180 ft. lbs.?!?!
    Which "spring bolts" are we talking about here? The u-bolts or the frame/shackle bolts?
  5. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    MJ: how come never use red loc tight?
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    If it is applied correctly you will have to heat red-loctite up and melt it, so you can remove the bolt.
    Usually red-loctite is used on reciprocating mass in engines.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Instead of bolts on the passenger side pumpkin, use studs. Torque is 150 lb/ft from all the info that has been posted on here...........no lock washers, no loc-tite of any kind is needed, just re-torque them a couple of times after the install and you are good to go.
  8. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Another good tip is to fill the void between the housing and the spring plate caused by the thicker spring pack of lift springs. You can fab a spacer out of steel, or if you don't have the equipment to fab this up you can use some hardened washers to provide some stability. I believe that the instability caused by this void is the main reason people break the bolts off in the housing. I fabbed a spacer out of 1/2 inch steel, but I am about to have to make a new one because I am going to add a set of ORD zero rates. Hope this helps.
    Mike
  9. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    could you post a pic of that spacer?? i recently had my bolts break and was thinking of adding some kind of spacer.
    the reason i think mine broke was my spring pack had a degree shim that didn't allow the spring plate to sit level.
    i removed the shim and at the same time removed the bottom leaf, so the gap that i have is less that an inch.
    i would just hate to go through all the repair all over again.
    ric
  10. Mr.Chevy4x4
    Jun 16, 2000
    1,932
    Sims, NC
    I don't have a pic, and if I took one now you really couldn't see anything but the end of it. I am running 6 inch Tuff Country ez-rides and my spacer requirements were 1/2 inch thick by 1.5 inches wide by 5 inches long. the width and length will remain consistent and only the thickness will change. I didn't have a drill bit big enough for the bolt holes so I drilled a smaller hole and blew the rest out with the "blue wrench"! It is extremely easy to fab! Hope this helps!
    Mike
