d60 spring plate
Discussion in 'The Garage' started by mccomas, Dec 16, 2003.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i laid out my d60 items for my weekend install and i realize that i have two passenger side spring plates #$%&$$*&@#!!! can someone tell me where to get a drivers side d60 spring plate with u-bolts - i am in a bit of a hurry on this. i wanted to start the install this weekend. i am posting this in the wanted and garage section. please do not recommend Echobit - nice guys but way too slow.
  2. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    get it from JKW , VERY beefy plates and very quick turnaround on them as well. pic....
    cheaper than factory plates, optional anti-sway bar attachment point, and they do custom plates as well if you want to relocate your axle (like i did) etc etc.
    as far as ubolts go, check yahoo yellow pages in your area, search for "spring" and find a spring shop. I just did this and found a great shop in portland that makes em for $8 each and they can make a set in under 10 minutes. fast enough for ya? /forums/images/graemlins/grin.gif
    j
  3. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I'm pretty sure a driver side spring plate from a GM 10 bolt axle will work, because I think the axle tube OD is the same. U-bolts on drivers side works too.
  4. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    i just assumed that the axel tube was larger on the d60 - i will measure it in the morning. anyone what to ring in? is the 10 bolt tube the same diameter as the d60?
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    no, 10 bolt plates do not work on a d60. contact jkw and all your problems will be solved.
    j
  6. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Off the top of my head I think the 10b is 3" and the D60 is 3.125" (3 1/8"). You might be able to make it work, but you will likely have to squeeze the u-bolts to make it in the holes. Do you need the sway bar mounts? If not I might be able to help you out fairly cheap.
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    contact TonyP, OR willyswanter on here I think they both make them
  8. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    i just bought a whole set from tonyp, and will have the stock spring plates for sale soon if u want to buy them.
