D60 steering block install?
Discussion in 'The Garage' started by Ned Kelly, Mar 21, 2005.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Can anyone tell me what the correct procedure is for installing the four D60 steering arm knuckle studs? I put a 4" steering block in (until I can get crossover) but the studs have loosened up on me a couple of times. Thanks.
  2. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    A bit of loc-tite on the threads might help. Loose studs on the steering block sucks. I had three of them shear exiting Lower Helldorado at BB03. Ended up having to leave my truck in the wash overnight...
    We ended up using long fine thread 1/2" bolts and lug nuts with the right seat taper. It was meant to be a temp fix, but I drove it like that for over a year.
    Rene
  3. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I ended up using lug nuts also. I'll have to check if they are the right taper. Theyl seemed ok but I should double check. I had to use a nut-splitter to get the old ones off the studs. Thanks
