d60 steering correction
Discussion in 'The Garage' started by dan johnson, Apr 18, 2007.
  1. dan johnson
    dan johnson Registered Member
    Mar 22, 2007
    13
    minnesota
    i have a 85k5 that has 8" of suspension lift i just swapped is a d60 front just wondering what i should have for steering correction? i already have that drop arm that mounts to the steering box. also is crossover steering worth it its pretty expensive isnt it? thanx dan
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    at 8" of lift i think you really dont have any other options than crossover.
    A drop pitman arm + a drop draglink + a raised steering block could probably net you the 8"s but you'd have to spend at least half the money to go crossover and still have the push-pull steering... i think you need to bite the bullet on this one and pay to do it the right way
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    If you only drive this on the street, then maybe you can get by without crossover steering.
    If you plan on doing any kind of offroading, the stock type steering setup will dissapoint you.
    I only had a 4" lift and the stock steering setup was pretty much unusable for me. Flex is pretty important in the rocks though.
  4. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I agree, if you don't wheel it then you can prolly get by without crossover. If you wheel it you will def want crossover. I did a bad thing by letting you know I have some parts you may be interested in and posting that info here. I have been policed so now I gotta reconcile. I've heard of people using dodge arms to gain some hieght. My current set up with a 3" block and 2" drop drag link and chevy steering arm are below.
    The drop draglink from the side with the 1/2 ton axles.
  5. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    http://coloradok5.com/forums/showthread.php?t=186304:thinking:
  6. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Crossover Would be the thing to do for safty if anything else.
