D60 studs?
Discussion in 'The Garage' started by 85mudblazin, Jul 16, 2006.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Anyone know where to get JUST the studs?? Every place I find that has them wont sell just the studs, you have to get the u-bolts to.
    -Chris
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Call NWF
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    got my ARP studs from ORD.
    j
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    ORD said they wont sell just the studs, you have to buy the whole u-bolt kit which I have no use for:mad:
    Ill try NWF and see what they say.
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    NWF= Negative, he didnt even know they had studs for them, he just kept saying there 5/8" bolts:mad:
    Any other ideas??
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  8. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How about contact ARP direct?
    1863 Eastman Avenue
    Ventura, CA 93003
    Hours: 7:30am - 4:30 pm PST
    email: info@arpfasteners.com
    Order Desk & Technical Support: 800.826.3045 or 805.339.2200, fax: 805.650.0742
    Specialty Products (Non Catalog Items): 805.525.1497, fax: 805.525.1441
    Sales & Marketing: 800.826.3045
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    What about some of the axle mfg's like Dynatrac, Rockcrusher, Currie, etc?
    If you know the size, tpi, length, etc... ARP probably would be your best bet.
  10. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Called ARP and they said they dont carry any studs bigger then 9/16":mad:
  11. jolane
    jolane 1/2 ton status
    May 27, 2004
    132
    The studs I just got from ORD do not appear to be from ARP. Instead, they have a sybmol stamped into the ends, but I do not recognize it. I am at the point where I may not use my studs I just got. Haven't finalized the decision yet whether I want to use Zero rates or not. Unfortunately it appears that the studs only work with extremely thick spring packs or zero rates and regular spring packs. Not sure why they are set up this way...useless unless I go ZR's.
    Why not just use bolts? I am not sure what the advantage is of the studs. Seems Gr. 8 bolts would be more than good enough. The stock bolts are only Gr. 5.
    Joshua
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    The bolt are my problem. I guess from them being removed and installed so many times one of the holes just stripped out on its own. So if I install a heli-coil I want to use studs so this doesnt happen again.
    But I think I am just going to re-drill and tap the holes to 3/4" and run some course B7 3/4" all thread for the studs.
  13. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    That sounds like a plan
  14. evo
    evo Registered Member
    Dec 11, 2002
    30
    oregon
    thats what i did. it fixed my problem.
  15. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Ok, resurrecting this thread to ask a question. The bolts I have in my D60 just keep popping out of the case. What size is the stock bolt that is supposed to be in there? Is it coarse or fine? The ones I have in there are coarse and I'm wondering if they have stripped or whether I put the wrong ones in?
  16. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    5/8" coarse thread,
    And for 85mudblazin, I have a hardware store by me that has every size imaginable when it comes to fasteners. Let me know exactly what you want. I can mail it out ASAP if you like... (sorry, i missed the thread before)
  17. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    Both my friend an I are using Grade 5 studs, nuts & washers from a local nuts & bolts shop, him for years and me for months now, with no issues. I just brought in the stock bolt and told him I needed 2 studs & nuts with this TPI and diameter. It was <$5
    The reason I (and most everyone I know) prefer studs over bolts is so that you can take the nuts off without threading in and out of the axle housing. This way you can take the spring on and off without risking damage to the axle housing threads..... you're just unthreading a nut from a stud.
    Mike
  18. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    One company you can try is Granger. They sell direct to the public.
  19. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I bought a superlift kit and did not use the studs.....if anyone is interested I could sell them.
    I saw 2 broken grade 8 bolts on a d60 last weekend. Not sure what he did to break them. I still think it was from the pismo landing.
  20. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Turned out my problem was too small of bolts after all. Apparently they were 9/16's so I swapped in 5/8 bolts and it is just fine.
