D60 studs...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCJimmy, Sep 13, 2003.
  1. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Looking for the specs on the passenger side studs for a D60.
    Would prefer to install studs instead of bolts...
    any suggestions?
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Just buy this kit from 4wheel parts part # SUP 3418 it is the studs and u-bolts for 40$ great deal IMO.
  3. SCJimmy
    Mar 7, 2003
    406
    Thanks!! /forums/images/graemlins/thumb.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The size of the bolt/stud is 5/8" x 11 TPI, length depends on thickness of your spring pack.
  5. SCJimmy
    Mar 7, 2003
    406
    When I install the 60, I will be hanging a set of TC 4" 3 leaf EZ rides over them. I'm wondering if the studs in the 4WP kit above will work? /forums/images/graemlins/thinking.gif
    Byron
  6. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    They should, especially if you use the stock d60 spring plates.
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How hard was it for you guys to get those studs out?
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Mine had bolts when I got it so it was easy. But I would believe double nutting the stud it should come out just as easily as a bolt.
