d60 thoughts
Discussion in 'The Garage' started by unick, May 28, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    I just had an idea which Ill never do but I wonder if it will work. Could you take a ford D60 and dissasemble it. Then remove the axle tubes and switch then around? Basicly turn it into a chevy D60? I have no plans on doing this but I would lkike to know if itll work.
    lmk
    Nick
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    You mean like flip the axle over to get the pumpkin on the other side? It would rotate the wrong way like that.
  3. unick
    Aug 16, 2003
    4,286
    no not flip it over swap the axle tubes around. so it would work in a chevy.
    nick
  4. speedyvision917
    speedyvision917 1/2 ton status
    May 5, 2004
    472
    CT
    swap the ford axle tubes from one side to the other or put ones from a chevy in???
  5. unick
    Aug 16, 2003
    4,286
    yea swap the ford tubes
  6. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    it is really hard to get the tubes out. it can be done & it will work in a chevy though. i have seen the tubes cut in 2 & swapped w/ just the tubes welded together also
  7. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    THe spring pad would be on the wrong side of the pumkin
  8. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    the best way to do it would be too use new material for the tubes. then u can cheat the pumpkin over far enough that u can build perches on the tube instead of the pumpkin
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Or just leave the axle alone and use a ford 205.
  10. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    That solves it /forums/images/graemlins/rotfl.gif
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes you could, you would have to get it retubed obviously. I was going to do that, but did the 14b instead.
  12. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    K5MONSTER CHEV i like what you did with the 14 bolt. what did you do for gears tho, did you get some reverse cut gears made up, and what did you use for the steering parts dana 60 stuff? do you have a write up somewhere on this. Thanks Vince
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I dont know, that sounds weird. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thanks! /forums/images/graemlins/thumb.gif
    No I dont need reverse cut gears, everyone asked this, but if you think about it, the gears are exactly the same as a normal, low pinion front axle, which drives on the coast side of the ring gear, so no need for reverse cut gears!
    The knuckles out are all D60, so all the steering parts are the same as would be for a 60, mines from SKY, AWESOME products! /forums/images/graemlins/peace.gif
    As for the write up, I didnt even bother, seeing as how most people didnt like the whole idea, so I didnt waste my time. However if you would like any info, anyting specific, whatever, just let me know! /forums/images/graemlins/waytogo.gif
  15. unick
    Aug 16, 2003
    4,286
    man that is cool!!! How did you get the driveshaft to line up with the axles??
    lmk
    Nick
  16. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    This is where I'm going. Not weird. /forums/images/graemlins/thumb.gif
  17. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    or talk to me and get a driver side fix'd yoke 241!!!!! /forums/images/graemlins/peace.gif /forums/images/graemlins/woot.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
  18. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Come on Stephen say it. Leave your 203 in place and run a Ford 205 off an ORD Doubler. I was going to do it until I got a good deal on a GM 60.
