D60 tie rod ?
Discussion in 'The Garage' started by BLZN4FN, Jun 10, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I need a super heavy duty tie rod for my 60
    What tie rod are you using? where did you get it and is it solid or hallow?
  2. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    solid rod
    I make them out of 1.25" diameter solid rod and drill & tap the ends with 7/8-18 LH & RH thread.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I had a tierod end go bad... before I put the truck on the road recently... was bad on the d60 I got... so I bought it from ABC as they were going out of business... got the $90 long side for $35!!!!! so I was like... WTF might as well replace the other.. shortie side... that was $48 marked down to $12!!!!!
    so I get home and goto put them on and where they connect doesnt fit... seems these were BEEFIER than what was on the truck... 1979 GMC K35 tierods are HUGE!!!!!
    original
    bigger pic of it.... http://www.supermotors.org/getfile/193917/original/d60e.JPG
    dont have a pic but will see what I can find....with the replaced one... or take one today... but it is HUGE
  4. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    I have rockstomper, 1.5" tube with 5/16" wall thickness. I don't think they do much steering junk anymore. If I was you, I'd contact blackwidowperformance.com. They are long time ck5 members and can make you a beefy tierod np.
    j
  5. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
  6. Scott39
    Scott39 1/2 ton status
    Jan 3, 2005
    214
    Lakewood, CO.
    I have the ORD tie rod with the 1 ton rod ends.The rod is 1 1/2 inch x 3/8 wall.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Sky Manufacturing
  8. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I run the ORD rod and it is tuff. I have beat it on the rocks hard and it is still straight.
  9. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
