D60 TRaction aid?
Discussion in 'The Garage' started by chiefheaphy, Apr 25, 2007.
  1. chiefheaphy
    chiefheaphy 1/2 ton status
    Mar 13, 2007
    632
    East MASS
    Does anyone run or know the powerlock traction aid? THey are a bit cheaper and supposedly "less violent" than the detroit. I'm building a 90% trail rig on either 44" or 46"'s. Should I just go with the Detroit Locker or is the Power lock worth the money($400)?
  2. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    2 sides to it..
    i went with the powertrax, im running 42's and a big block in a buggy with chromo shafts and flanges
    in a set up with bigger tires I would do the detroit..but your shafts will be in danger in sure!
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    A powerlock is not a locker, its a limited slip.
    Why are you worried about "violent" engagement with a basically trail only rig? Any mechanical locker will be locked up all the time when you are in 4 low.
    Even if you have chromoly shafts and u-joints you will have trouble with gears and lockers breaking. A spool, detroit or ARB are really your only options IMO (they are listed in order of strength).
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I have a regular limited slip and it sucks. I hate it. No traction on rocks at all...once one tire starts to slip then it takes a big dump right on your face. I heard a Power locker is not as lame as a regualr limited slip but I wouldn't chance it. Buy a detroit, ARB, OX lunch box locker...etc etc. etc Spend the money 1 time instead of twice.
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    DETROIT
    and get chromo shafts or say bye bye with a built motor and a heavy right foot with 44's-46's
  6. 1977k5
    May 26, 2003
    9,994
    130
    I would not even consider a lunchbox locker with 40" tires or bigger, the stock cast carrier will not hold up to it.
  7. 1977k5
    May 26, 2003
    9,994
    130
    Anyone would be lucky to get a 60 to hold up to 46's regardless of horsepower
  8. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    very true. im just saying that chromos would make it more likely that they would survive for a little:D
  9. 8_YOUR_H2
    Feb 20, 2000
    2,663
    Iowa
    Do you have any examples of a stock carrier breaking, any real life info. I would like more details as I was considering an aussie when they come out in 2050
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I would personally do a Detroit. I have seen a lockright (by powertrax) brake with 42" tires and I have seen one live a long life with 40" tires. It is a crap shoot but with anything over 40" I would highly recommend a Detroit. I am not a fan of spools in the front & I am not a fan of ARB's therefore I am saying Detroit all the way. They are strong & reliable.
    Harley
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Posi = limited slip = limited traction :p:
    My buddy had a Powr-Lok in his D80 Dodge. It would still let loose on deteriorated/deactivated logging roads (not rockcrawling by any means) so we found an open diff and got a Lockright for it.
    Traction is now as it should be. We figured the Lockright is cheap enough that nobody's going be crying if it don't last as long as a Detroit. Same reason I put one in my D60 front. (Detroit later if it expires). No more limited slip/traction for me thanks.
  12. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Isn't it true that with a detroit- or most any locker, if you break a shaft the sudden jarring will exploded the locker? I likely won't ever have $650 for a detroit so I'm considering welding it.
  13. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    What kind of trails are you running with a 24" lift?
  14. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    trails
    Mud, hills. Shallow Lakes/seas. Beach
    Prob not a lot of rock crwlin. I'll build another one for that.
    Since I was about 8 I've had a picture of this big bad blazer in my head so I have to build it so I can see it for real. Functionality will come with the next one.
    Ive got 4340 35 spliners. Sounds like Detroits front and rear is the way to go.
    Now im leanin to 44" boggers.
  15. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    I've read about that quite a bit on Pirate. Haven't seen it for myself, but that would really suck! I've got a detroit in my 60 but I haven't really used it yet :haha:
  16. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    You just didn't realize you were using it cuz you cruise over everything.:wink1:
  17. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have snapped 3 GM 10 bolt front axles and have not broken my lockright yet. A lockright is weaker then a Detroit so I would not be to worried about breaking the Detroit.
    Chromo shafts in a D60 puts the axle breakage at a guess at best. If you have locking hubs it will be those most likely. If you have slugs then it is a gamble on whether it will be an axle, locker, R&P, or yoke.
    Harley
  18. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    Word, I went through about 5 shafts/ujoint failures and 1 lockout with my lockright and 10b(reason for the upgrade lol). Lockright held up fine. It didn't take much to pop those 10b shafts though.
    Now I've got Yukon 35 sp outers and slugs in the detroited 60. Hopefully I don't find the weak link for a while. D60 parts are spendy:laugh:
  19. chiefheaphy
    Mar 13, 2007
    632
    East MASS
    gears
    what would be a good ratio to go with?
    i'm thinking somewhere in the 5.38 -- 5.86 range.
    ive got a bored 350(probably will go with a 454 down the road), sm465, 205.
    With 24" lift and 44 or 46 I can't see myself doin much more than 55mph.
    How difficult is it to install gears and locker?
  20. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    If you have a 70 rear I would go with the deepest gear.
