D60 tube seals?
Discussion in 'The Garage' started by Ned Kelly, May 1, 2007.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
  2. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    There is, albeit, I can't rememeber who. also, I have seen a few threads about using carpenter's foam to accomplish the same thing.
  3. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
  4. peterpan
    peterpan Registered Member
    Aug 18, 2006
    95
    WYOMING
    i seen the jeep ones in a magazine and wondered that allso
  5. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Yea I just bought a set of those from MAD. Haven't installed them yet and I'm still suspicious of them even working. I posted up on a couple boards asking who has run them with no responses. Either they are too new a product or people are just too suspicious of them to waste the money. I dunno- we'll see if they work.
  6. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    carpenter's foam? that's the stuff that expands out and seals in right? if it's leaking already would it work? i'm lazy lmao
  7. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    If it's leaking all ready? What you got gear oil running out the end of your axle tube? There are two dif types of that expansion foam- one stays pliable (preffered) and one turns rigid (not preffered). I was considering using old boddy bushings and grease the piss outta the area against the shaft.
  8. Randy92782
    Mar 25, 2007
    16,287
    Arcadia, MO
    yep gear oil out the axle tube. one started after i parked it. towed it to my dad's then the other one started. i just replaced all the bearings and lockouts then they started leaking. i hate to have to go back through all that work. dang things couldn't have leaked while i had them apart. geez...my works never done.
  9. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Sounds like you need to do an overhaul on the dif then. Pull the chunk and replace those seals. The outter axle seals are not to be used as a repair for the inner seals. Those are the crusial ones.
  10. Speedo
    Speedo 1/2 ton status Premium Member
    Oct 31, 2005
    474
    27
    Talkeetna, Alaska
    We put the Mad4wd seals in my wife's rig but they haven't been in there long enough to get any kind of results yet. We have had to replace the axle shaft seals several times in her buggy and if these tube seals help the inner seals live longer they will be worth it.
    Gus
