d60 u bolts
Discussion in 'The Garage' started by 86chevybanshee, Mar 1, 2005.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    anyone know the dimension for d60 u bolts and what size the bolts that go into the housing are?
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Mine is a dodge and i know the bolt holes are different, but i beleive the tubes are the same, 3 1/8th"s
  3. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    any spring shop can bend them and should have the specs for stock ubolts in there catologs.
  4. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    the closest spring shop is like 3 hours away. im not going that far for u bolts.
  5. sweetk30
    Nov 1, 2004
    25,547
    542
    i might be able to get them tomarow for you from my shop in town. pm me if needed
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    The holes in my GM D60 are 5/8-11. I strongly encourage you to use studs rather than bolts. Also, I reccommend buying the D60 ubolt kit made by superlift and sold by 4wheel parts. Normally, I don't use either one but in this case it's a really good deal and it comes with studs that are coarse thread on the bottom to match the housing and then fine thread on top to match the other Ubolts. All this hardware is plenty long enough for the thickness of aftermarket springs.
  7. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    thanks for the info beast
  8. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Beast,
    Do you know if those U-bolt kits are long enough to work with a aftermarket spring AND a 1" zero rate?
  9. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    i have 2 sets in the garage i can measure them after i unburry them in the crate...lol but if you still want measurements I can give them to you fo rthe stock bolts.
