D60 U Joint
Discussion in 'The Garage' started by ProJunkRacing, Jan 13, 2006.
  1. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    What is the best bang for your buck U joint for a Dana 60 Not talking CTM's but something decent for a reasonable price
    Spicer's?
    Thanks Dissasembled my D60 and need u Joints they are seized and will turn one way only not full artuculation so Since i am welded i wanted to fix em now before i blow a hub or something .
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    factory non greasable spicers.:D
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Thats what I got:D
    Ira
  4. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    Ive also got the spicer pieces. Good so far and Im welded up front also.
  5. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    Why the non-greasable?
  6. sandawgk5
    Oct 28, 2003
    6,881
    The theory is that with no lube passages there is more "meat" in the body of the joint therefore the joint is stronger.
    Ira
  7. sweetk30
    Nov 1, 2004
    25,547
    542
    bingo.
    my dads old plow truck would twist off greasable ones like butter. non cross drilled cross was much better. if in dout try to put a small screw driver in the hole to go to the center. the non drilled will be 1/4" deep or so and stop. just the amount to hold some grease.
  8. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Spicer Life series. 5-806X is the part #. The biggest reason they're stronger than the greasables is cause they're cold forged rather than hot forged. The lack of grease passeges helps I'm sure, but the cold forged part is the most significant.
  9. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I just got my set of Longfield 300M's a while back. A bit more than the spicer, a bit less than a CTM. I break it, they replace it. I doubt I'll ever break one (knock on wood) but if I do, it's nice to know it will be replaced for free.
  10. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    but where can i get the spicers and what is the cheapest i could pay for them i wanted to just go to autozone for 15 bucks but you get 15 dollar quality.
    napa's were 44 a pop and (precision ) lifetime warranty
    carquest was 46 a pop (neapco ) lifetime
    autozone 15 a pop (????) 1 yr warranty
  11. sweetk30
    Nov 1, 2004
    25,547
    542
  12. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
  13. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I"ve also bought from him, good seller to deal with.
    I got the greasable Spicers because I run alot of mud (open D60/454 auto/39.5's). Never broke a u-jt in 15yrs,I lube them LOTS after every mud run. Just replaced the u-jts about 9 mths ago. If your rock driving greasable may not be an issue, and that extra strength may be a factor. I did read a ujt comparison article a few years ago, and they stress tested ujt's on a torque meter. Failure points on solid and greasable Spicers were within 5% of each other. Not sure if there was a cold forged ujt in the test. Were cold forged solids available 5 yrs ago (about the time of the article)?
  14. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    i don't know timmay told me to wait see if he has some at his mom's house and i kinda wannt get my junk together and out on the trail by next month when i turn 20 . It has been almost a year since i bought it and it must be ready for mud blast fathers day weekend . I think i will wind up with spicer's tho seeing as i am going to be spraying around a 150 shot .
  15. JeffHK5
    JeffHK5 1/2 ton status
    Mar 16, 2005
    544
    Cincinnati
    Yep , Longfeild 300Ms . There $330 a set to your door and they have a lifetime guarantee, hard to beat.
    I hope that some competition for CTM will bring there prices down!
    Jeff
  16. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    got pictures? that price is high for just a trail rig that isn;t so hardcore yet
  17. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    Go to Pirate for all the info and pics on the Longfield 300M joint, it's much better than I could do.
    As for the "not hardcore" thing , a locked Dana 60 is enough of a reason for a good set of front joints. I have Alloy front inner/outer axles and a blown joint could take out more overpriced stuff!
    Jeff
  18. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    can the same u-joints be used for both 30 and 35 spline outers? or is there like a conversion u-joint for it?
  19. JeffHK5
    Mar 16, 2005
    544
    Cincinnati
    Same joint
  20. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Ditto to what KidJethro said. I run em, and run em hard.
