D60 with 8 degree Offsets / What did you do?
Discussion in 'The Garage' started by 45acp, Feb 10, 2003.
  1. 45acp
    45acp 1/2 ton status
    Jan 3, 2001
    695
    Tucson, Arizona
    I have a Ford D60 in my Jimmy so I don't have this problem but fellow CK5er bought Offsets for his GM D60 and then asked this question. When his axle is rotated 8 degrees the 2 bolts that screw into the axle housing for the spring clamp bolts will not set level with the top clamp plate. The bottom of the bolt head will be on a angle of 8 degrees with the top plate.
    My suggestion was to buy special wasers from McMaster-Carr. I looked these up and they are Spherical Steel Washers, one is concave and the other is convex. They mate together and can rotate for the proper angle. I don't know what size the GM bolts are but Ford is .625 diameter. I'll give 2 sizes from McMaster-Carr as follows.
    .625 = P/N 91944A480 and cost 12.14 each pair/set
    .750 = P/N 91944A490 and cost 16.31 each pair/set
    McMaster-Carr phone number is 1-562-692-5911 or
    www.mcmaster.com
    How have you solved this problem with your GM D60 axles? /forums/images/graemlins/confused.gif
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I'd imagine the top spring plate holes would need to be slightly hogged too. Combine that with tapered washers and you should be good to go.
    Rene
  3. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    8 degrees
    isn't that a bit much for a front axle??
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yep.
    And yer making your steering caster angle 8* more negative. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ignore.gif
  5. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    After rotating a housing, I would suggest plug welding the holes, then drilling/tapping new ones. Make a new spring plate with the holes drilled at the proper angle.
  6. stumpjumper
    stumpjumper Registered Member
    Feb 8, 2003
    16
    east texas
    i have a 12 degree shim on mine and what i done was screw in some allthread and heated them up a bit and bent them back to a strait shot and the plate went right down over them , i have been running like this for a long time now and so far i have had no problems but he will need to grind the knuckles loose and rotate them back or it will a chore to drive down the road , i tried to see how bad it really affected the steering and it was so bad i couldnt hardly keep it inbetween the ditches but i am running 12 degrees instead of 8 but im sure 8 will be noticeable also
